Engine Loom
Revision as of 19:25, 27 January 2012 by Grrrmachine (talk | contribs)
The main engine loom is a crazy snake of wiring independent of the main vehicle Loom. It connects to the main loom via the C101 plug, and connects the engine ancillaries together for the ECU.
This engine loom is the most common version, the Motronic 1.3 loom. If you are converting your engine to an M5x unit, compare this diagram with the M5x loom.
Number Function Pins Image
2 Battery +
3 Oxygen sensor
4 Coil -
5 Coil +
6 Ground
7 Starter
8 ICV or TPS
9 ICV or TPS
10 Starter
11 Alternator
12 Alternator
13 Oil level sensor
14 C191
15 CPS or CID
16 CPS or CID
17 Diagnostic connector
18 Oil Pressure switch
19 C101
20 AFM
21 Carbon Canister valve
22 Relays
