The main Loom contains all the wiring for your E30. It forms the core of the Electrical system.
From the front to the rear Lights and everything in between, the wiring inside your E30 is a one-piece unit that accomodates all the primary functions of the vehicle. This bundle of cables is known as the Loom, and its hub is the fuse box, mounted on the inner wing inside the engine bay.
The Loom is a standard design across all E30 models, with minor differences between years. Unsurprisingly for BMW, its design means that every element is fed with its own custom-made socket to make connection and disconnection of each component simple, and a standardised wire colour scheme means that cables can easily be identified by their colours and location.
Secondary looms for removable or optional components, from the engine to the radio, make use of sub-looms that connect to the main loom at special plugs. These plugs are referred to by letter and number, and start with the main engine plug, the C101.
Fuse Box
Main article: Fuse Box
The Fuse box is the beginning and end for every key wire in your car. Mounted inside the engine bay against the bulkhead, it is a single-body unit with up space for 30 fuses and 10 relays, 8 of which are removable.
Relays
Main article: Relays
To help switch components on and off, a number of relays are fitted within the loom. We've documented their locations, so that you can locate the source of that irritating clicking sound.
Accessory Socket
Located under the glovebox on RHD vehicles, the Accessory Socket is a multiplug port that allows quick fitting of optional extras, without having to splice into the main loom. It is referred to on wiring diagrams as C302.
| Terminal | Circuit | Terminal | Circuit | Image |
| A | Not used | N | Not used |
| B | Not used | O | Not used | |
| C | Not used | P | Not used | |
| D | Central Locking | Q | Power Windows | |
| E | Not used | R | Cruise Control | |
| F | Not used | S | Cruise Control | |
| G | Not used | T | Not used | |
| H | Board Computer | U | Heated Seats | |
| I | Not used | V | Radio | |
| W | Radio | |||
| K | Not used | X | Radio | |
| L | Not used | Y | Radio, Ground | |
| M | Not used | Z | Antenna | |
Plugs
The whole point of the loom is to connect each electric component in the vehicle, and therefore the whole mass of wires is populated with multipin, multicolour and multi-purpose plugs. While it would be impossible to document every single plug in the vehicle, we can list some of the most important ones here.
If you have found a plug and aren't sure what it's for, check the wiring diagrams.
C101
Main article: C101
The biggest terminal point of the car loom is the C101 plug. This multipin connector sits in the engine bay (usually on the bulkhead), and allows the different engine looms to connect to the standard vehicle loom. This means that you can disconnect, remove and replace an engine without disturbing the main wiring for the vehicle.
Because all the engine wiring runs through this plug, it's a great place to start looking for wiring problems when troubleshooting. A full pin-out of the C101 plug is contained in the main article.
C191
Main article: C191
The C191 plug sits in the engine bay, underneath the intake manifold. It is the main plug for the fuel injectors, but also carries coolant temperature information to the ECU and temperature gauge. It is a known problem area for E30s, and can be the source of a number of engine problems.
Door Loom
Main article: C40x
Referred to by BMW as connections C404 and C405, the door loom plugs are fitted into the A-pillar of the shell and allow the doors to be disconnected for removal. Because of their location and exposure to the elements, the various pins of these connectors can corrode and break over time, leading to a general failure of components such as the electric windows, mirrors and especially the central locking.
A full pin-out of the door loom plugs is contained in the main article.
Wiring Diagrams
Main article: Wiring Diagrams
BMW didn't try to document the loom all in one go, and we won't either. But the Wiki does contain diagrams collected from a number of resources, broken down into sections to help you troubleshoot your electrical problems. Check out the Wiring Diagrams for a complete list.
