Revision as of 19:05, 17 December 2011 by Grrrmachine (talk | contribs)
Clutch Disc
The clutch disc is the surface that presses up against the engine flywheel. It's outer rim is covered in friction pads, made of an asbestos-like material that grips the face of the flywheel. It's when these friction pads wear down that the clutch is effectively dead, and needs replacing.
Pressure Plate
Release Bearing
The Release Bearing is how we engage and disengage the clutch. When no pedals are pressed, the Pressure Plate presses the Bearing against the clutch disc, engaging drive. When the pedal is pressed, the Release Bearing is pushed away from the clutch disc, allowing the clutch to turn with the gearbox shaft, but not to spin with the flywheel.
When the pedal is then released, the Pressure Plate pulls the Release Bearing back against the clutch disc, engaging drive and transferring the power from the engine to the wheels.
Master Cylinder
Slave Cylinder
The Slave Cylinder is another fluid syringe, just like the Master Cylinder. When the Master is pressed in by the clutch pedal, the Slave is pushed out, which presses the release lever inside the Pressure Plate.
The Slave cylinder is bolted directly to the gearbox with two 13mm bolts, the top one of which is notoriously fiddly to access. It is also fitted with a bleed nipple to remove air from the hydraulic system.
Pedal Feel
If your pedal is becoming either too hard or too soft, or the biting point is rising and falling, then it is very likely that either your Master or Slave cylinder is failing. Check under the car and under the pedal for signs of fluid leaks. If you believe either cylinder has failed, then replace both at the same time. Failure to replace both will lead to increased pressure on the older cylinder, causing it to fail imminently anyway.
Bleeding
  1. Crack off the bleed screw with a proper brake spanner to reduce the risk of rounding off the bolts.
  2. Unscrew one quarter turn
  3. Have assistant press AND HOLD the clutch pedal
  4. Retighten bleed screw
  5. Have assistant release clutch pedal
  6. Repeat steps 2-5 until fluid seeps from the bleed screw. At this point, tighten the screw fully.
