Installing VDO gauges
Revision as of 09:15, 16 December 2011 by Grrrmachine (talk | contribs)
Gauges
Oil Temperature
The Audi Oil Temp gauge has a range of 0-170°C. VW gauges will show 0-150°C. It is also possible to find 0-120°C gauges; some will say Oel (oil) while others will show the standard Coolant image, but they are identical units underneath.
The oil temp gauge is driven by a single thermistor sender. This little unit looks like a bolt with a pin on top, and has no moving parts. Once screwed in and wired up, a basic current is passed through the sender, earthing through the engine. As the temperature rises, the sender's internal resistance is lowered, increasing the current and therefore increasing the power to the gauge. This makes the needle move more to one side, and therefore reading a higher temp. How simple. What's important is to use the right sender for the gauge, so here are the VDO part numbers to order the appropriate sender (if you haven't got it already):
M10 x 1.0 M12 x 1.5
120°C 049-919-563B
150°C 323-804-006-005D or 323-804-006-006D 323-801-010-003
170°C 323-804-015-001D
Oil Pressure
The Oil Pressure sender is the most significant part of the system, and should be a fat metal canister with a threaded bolt at the bottom and one or two pins at the top. These top pins will either be spade connectors or threaded posts with nuts; both can be used in your E30. If your sender has two top pins, it means you don't need the oil pressure switch which is currently fitted to your engine, since that function is built into your new sender.
The most important part is the pressure rating of your sender; on the side of the bottom bolt face should be a pressure rating; 0-5 or 0-10. It is essential that this matches the range of your pressure gauge. The sender part numbers are:
  • 0-5 bar -
  • 0-10 bar -
Volts
Some consider the Volt Gauge or Voltmeter to be filler; an extra dial to make the cockpit look more advanced, more technical. While it's certainly not as crucial for the engine as the Oil gauges, the Volt gauge is very important for assessing the health of your charging system, and lets you know how your alternator is doing, whether your battery is up to the job and whether you've got a serious power failure on your hands.
Unlike other gauges, the Volt gauge needs a simple connection to a switched 12V supply; there are no senders required to make the gauge work, and is therefore a very simple addition to the instruments.
Gauges
Gauge mounting plate
The gauges you will be using are most likely the 52mm versions fitted to Audis and VWs. Sometimes these will come mounted in a plastic frame, but are easy to disassemble.
On the back of each gauge, you will see two threaded posts. These are the mounting arms for the mounting plate, which is a C-shape of metal with two holes to fit onto the mounting arms. The plate is held in place with two furled nuts. The idea is that the plate pushes against the back of the fascia, sandwiching the gauges in place. If you bought gauges without the mounting plate included, you will have to get creative and make your own.
Depending on where you want your gauges, you will have to fabricate your own fascia or buy one from our Zone traders such as Kos. To make your own:
  • Decide where you want to place your gauges, and take some measurements
  • Find a piece of plastic to use as a fascia, and cut it to size so that it fits the area you want it
  • Using a hole saw, drill holes the same size as the BODY of the gauge, but not as big as the face
  • Drop the gauge into the hole from the outside
  • Turn over, and fit the mounting plate onto the mounting arms. The feet of the plate should be pressing against your piece of plastic
  • Screw on the furled nuts until the gauge is locked in place tightly
  • Depending on placement, you will need to devise a method to hold the fascia in place
Placement
Tuning companies such as Hartge and Alpina offered additional pod units that sat on top of the dashboard; these were either extensions of the main instrument binacle, or standalone pods that sat on either in the centre or the passenger side of the dashboard. By placing the gauges on the same level as the other instruments, they gave the driver a more natural viewing position.
However, it is very hard to get hold of these pods, and aftermarket alternatives are of generally poor quality. They also necessitate drilling, cutting and gluing the dashboard, which is something you may be very reluctant to do.
Because of this, we recommend you choose one of these locations to fit your gauges. All three will necessitate a small amount of fabrication, but this can be done with standard plastic sheet rather than building a complete gauge pod.
Top Air Vents: This is where Alpina mounted their infamous Digital Dash Unit. By popping out and blocking up these central vents, you will be able to mount up to four gauges, or keep one vent and fit two gauges. This places the gauges in the most visible position, at the expense of losing an element of the air vent system, which is no real loss.
Ashtray: A very popular choice, and one of the Zone team sells fascias ready made for this location. The gauges are not obscured by the steering wheel, and no permanent damage needs to be done to the interior to mount the fascia. The downside is the loss of the ashtray, which is unacceptable for smokers and people who keep small change in their cars. Three gauges can be fitted here, or just two while retaining the cigarette lighter.
Under Heater Controls: Often referred to as the cubby hole, the area above the ashtray and below the heater controls seems perfect for an extra panel; so good that this is where Hartge often mounted their instruments. Placing your gauges here means you don't have to sacrifice any other features of the Interior.
Senders
rear view of the Oil Pressure Gauge
