Revision as of 17:39, 19 November 2011 by Grrrmachine (talk | contribs)
Plate
Master Cylinder
Slave Cylinder
Manual
| 316 | 316 316i 318i | 323i Sport | 318iS | 323i 324td 325e | 325i Sport | |
| 1st | 3.76 | 3.72 | 3.76 | 3.72 | 3.83 | 3.72 |
| 2nd | 2.04 | 2.02 | 2.33 | 2.02 | 2.20 | 2.02 |
| 3rd | 1.32 | 1.32 | 1.61 | 1.32 | 1.40 | 1.32 |
| 4th | 1.00 | 1.00 | 1.23 | 1.00 | 1.00 | 1.00 |
| 5th | 0.81 | 1.00 | 0.80 | 0.81 | 0.80 | |
| Reverse | 4.10 | 3.45 | 4.10 | 3.71 | 3.46 | 3.46 |
| Getrag 242 | Getrag 240 or 242/5 | Getrag 245 | Getrag 260 | Getrag 260/5 | ||
- Getrag 240 - MN or BMV
- Getrag 242 - LF, MD or BMU
- Getrag 242/5 - AY, AW or LG
- Getrag 245 - BJ
- Getrag 260 - NW, ANB or TNW
- Getrag 260/5 - TNN or HM
Automatic
| 1st | 2.48 | 2.73 | 2.48 |
| 2nd | 1.48 | 1.56 | 1.48 |
| 3rd | 1.00 | 1.00 | 1.00 |
| 4th | 0.73 | 0.73 | |
Selector
Propshaft
Guibo
Bearing
Main article: Differentials
