Revision as of 17:37, 19 November 2011 by Grrrmachine (talk | contribs) (New page: =Clutch= ==Plate== ==Master Cylinder== ==Slave Cylinder== =Gearbox= ==Manual== A range of gearboxes were used in the E30. {| class="wikitable" |- |+'''Manual Gearboxes''' |- !rowspan...)
Plate
Master Cylinder
Slave Cylinder
Manual
Manual Gearboxes
Four-Speed Five-Speed
316
318i
316 316i 318i
320i 324d
323i Sport 318iS 323i 324td 325e
325i 325iX
325i Sport
1st 3.76 3.72 3.76 3.72 3.83 3.72
2nd 2.04 2.02 2.33 2.02 2.20 2.02
3rd 1.32 1.32 1.61 1.32 1.40 1.32
4th 1.00 1.00 1.23 1.00 1.00 1.00
5th 0.81 1.00 0.80 0.81 0.80
Reverse 4.10 3.45 4.10 3.71 3.46 3.46
Getrag 242 Getrag 240 or 242/5 Getrag 245 Getrag 260 Getrag 260/5
  • Getrag 240 - MN or BMV
  • Getrag 242 - LF, MD or BMU
  • Getrag 242/5 - AY, AW or LG
  • Getrag 245 -
  • Getrag 260 - NW, ANB or TNW
  • Getrag 260/5 - TNN or HM
Automatic
Automatic Gearboxes
Three-Speed Four-Speed
316 318i 320i 323i 325i
1st 2.48 2.73 2.48
2nd 1.48 1.56 1.48
3rd 1.00 1.00 1.00
4th 0.73 0.73
Reverse 2.09 2.09 2.09
ZF 3 HP 22 ZF 4 HP 22
Selector
Propshaft
Guibo
Bearing
Main article: Differentials
Output Flanges
Drive Shafts
