Revision as of 15:36, 22 October 2011 by Grrrmachine (talk | contribs)
Brake Pedal
Brake Light Switch
Brake Servo
Intake Valve
Master Cylinder
Reservoir
Pressure Valve
Underneath the Master Cylinder is a pressure valve, for the rear brakes.
Brake Fluid
DOT 4 braking fluid should be used, although DOT 5.1 non-silicon is an acceptable alternative. It is essential to use non-silicon fluids as it can cause failure of the rubber seals in the calipers.
Brake Lines
Brake Hoses
Calipers
Discs
Pads
Drums
Cylinders
Shoes
Handbrake
ABS
Main article: ABS
For ABS vehicles, the rear ports of the Master Cylinder are blanked off.
Bleeding
Replacing Pads and Discs
Replacing Fluid
Replacing Rear Shoes
Soft Brakes
Air
Pulling
Squealing
Stuck Brakes
Main article: Brake Upgrades
Remember, bigger doesn't always mean better; massive discs with 4- or 6-pot callipers will add a massive amount of weight to your vehicle, especially its suspension, and you may have difficulty finding wheels that fit. It's often enough just to fit racing-spec pads and discs, and keep your system in top performance with regular servicing.
