Revision as of 12:45, 20 October 2011 by Grrrmachine (talk | contribs)
Brake Pedal
Brake Light Switch
Brake Servo
For those attempting an M50 or M52 engine swap, a Renault Clio brake servo is a smaller alternative than the standard unit, requiring very little modification to fit.
Intake Valve
Master Cylinder
Reservoir
Brake Fluid
Brake Lines
Brake Hoses
Calipers
Discs
Pads
Drums
Cylinders
Shoes
Handbrake
ABS
Main article: ABS
Air
Pulling
Squealing
Stuck Brakes
Main article: Brake Upgrades
Remember, bigger doesn't always mean better; massive discs with 4- or 6-pot callipers will add a massive amount of weight to your vehicle, especially its suspension, and you may have difficulty finding wheels that fit. It's often enough just to fit racing-spec pads and discs, and keep your system in top performance with regular servicing.
