Doors
Revision as of 08:14, 5 October 2011 by Grrrmachine (talk | contribs)
Doors
Windows
Facelift electric window mechanism
Wing Mirrors
Locks
If there is a problem with your locks, learn more about repairing your door locks. Main article: Central Locking
Electrics
  • Door locks
  • Door lock heater (if fitted)
  • Wing mirrors
  • Electric windows (if fitted)
Trim
To remove the bump trim, remove the 10mm plastic screw from the door jamb and then pull the strip firmly away from the door. It is held on with two plastic clips, which can only be removed from inside.
Rust
Sticky Windows
Electric Windows not working
To troubleshoot, use a flat screwdriver to prise up two window switches from the centre console, and swap them over. Now test the windows. If they work, the fault is the switch, which is usually dirty contacts. These can be cleaned up with sandpaper and Contact Cleaner spray.
If none of your electric windows work, check the fuse. If your electric windows only work with the door open, but not with the ignition on, then the fault lies in the switching mechanism that diverts power from the ACC (accessories) to the IGN (ignition) circuit, and is governed by a small blue relay under the dashboard.
