Technical
Revision as of 16:39, 22 September 2011 by Grrrmachine (talk | contribs)
E30 Technical
Engines
Name Volume Engine Valvetrain Fuel Output Torque Engine code Years
316 1766cc 4cyl SOHC 8V Petrol 99hp (66kW) @4500 rpm 103ft/lb (140Nm) @4250 rpm M10B18 1982–1990
316i 1596cc 4cyl SOHC 8V Petrol 102hp (75kW) @4500 rpm 105ft/lb (140Nm) @4250 rpm M40B16 1988–1995
318 1766cc 4cyl SOHC 8V Petrol 104hp (77kW) @4500 rpm 103ft/lb (140Nm) @4250 rpm M10B18 1982–1990
318i 1796cc 4cyl SOHC 8V Petrol 113hp (85kW) @4500 rpm 122ft/lb (165Nm) @4250 rpm M40B18 1987–1995
318iS 1766cc 4cyl SOHC 8V Petrol 140hp (104kW) @4500 rpm 127ft/lb (172Nm) @4250 rpm M42B18 1989–1991
320i 1766cc 6cyl SOHC 12V Petrol 123hp (92kW) @4500 rpm 0ft/lb (0Nm) @4250 rpm M20B20 1982–1985
320i 1766cc 6cyl SOHC 12V Petrol 127hp (95kW) @4500 rpm 0ft/lb (0Nm) @4250 rpm M20B20 1985–1991
320iS 1990cc 4cyl DOHC 16V Petrol 192hp (143kW) @4500 rpm 155ft/lb (210Nm) @4250 rpm S14 1982–1990
323i 1766cc 6cyl SOHC 12V Petrol 139-150hp (104-110kW) @4500 rpm 0ft/lb (0Nm) @4250 rpm M20B23 1982–19850
325e 1766cc 6cyl SOHC 12V Petrol 101hp (75kW) @4500 rpm 103ft/lb (140Nm) @4250 rpm M20B16 1982–1990
325i 1766cc 6cyl SOHC 12V Petrol 101hp (75kW) @4500 rpm 103ft/lb (140Nm) @4250 rpm M20B25 1982–1990
325iX 1766cc 6cyl SOHC 12V Petrol 101hp (75kW) @4500 rpm 103ft/lb (140Nm) @4250 rpm M20B16 1982–1990
M3 2302cc 4cyl DOHC 16V Petrol 197hp (147kW) @4500 rpm 0ft/lb (0Nm) @4250 rpm S14 1986–1988
M3 2302cc 4cyl DOHC 16V Petrol 212hp (158kW) @4500 rpm 0ft/lb (0Nm) @4250 rpm S14 1989–1991
M3 Evolution 2302cc 4cyl DOHC 16V Petrol 197hp (147kW) @4500 rpm 0ft/lb (0Nm) @4250 rpm S14 1987–1987
M3 Evolution II 2302cc 4cyl DOHC 16V Petrol 217hp (162kW) @4500 rpm 0ft/lb (0Nm) @4250 rpm S14 1988–1988
M3 Sport Evolution 2467cc 4cyl DOHC 16V Petrol 235hp (175kW) @4500 rpm 0ft/lb (0Nm) @4250 rpm S14 1990–1990
324d 2443cc 6cyl SOHC 12V Diesel 84hp (63kW) @4600 rpm 112ft/lb (152Nm) @2400 rpm M21D24 1985–1993
324td 2443cc 6cyl SOHC 12V Diesel 114hp (85kW) @4800 rpm 162ft/lb (220Nm) @2400 rpm M21D24 1985–1993
Engine Swaps
M50 and M52 M30
Uploading images and files
To upload you'll need to sign-up. See the top right corner if you haven't already created an account.
Once logged in you will see the toolbox in the left panel has an Upload file link. You can use this to upload images for you pages.
To use an image in a page just use
[[Image:Filename.jpg]]
Please note filenames are also case sensitive.
Formatting
This page details the guidelines for how to edit pages on the zone wiki.
A great list of simple formatting options is on the Wikipedia site here: Wikipedia Cheatsheet
For pages that are incomplete please add the stub template by placing the following text at the start of your article:
{{stub}}
This will ensure that it's easy for users to find and update articles that need updating.
Tables
{| class="wikitable"
|+'''Table Title'''
|'''First Column Header'''
|'''Second Column Header'''
|'''Third Column Header'''
|We
|Love
|E30s
|Old
|Skool
|Cool
This should look like:
Table Title
First Column Header Second Column Header Third Column Header
We Love E30s
Old Skool Cool
