Technical
E30 Technical
Engines
| Name | Volume | Engine | Valvetrain | Fuel | Output | Torque | Engine code | Years |
| 316 | 1766cc | 4cyl | SOHC 8V | Petrol | 99hp (66kW) @4500 rpm | 103ft/lb (140Nm) @4250 rpm | M10B18 | 1982–1990 |
| 316i | 1596cc | 4cyl | SOHC 8V | Petrol | 102hp (75kW) @4500 rpm | 105ft/lb (140Nm) @4250 rpm | M40B16 | 1988–1995 |
| 318 | 1766cc | 4cyl | SOHC 8V | Petrol | 104hp (77kW) @4500 rpm | 103ft/lb (140Nm) @4250 rpm | M10B18 | 1982–1990 |
| 318i | 1796cc | 4cyl | SOHC 8V | Petrol | 113hp (85kW) @4500 rpm | 122ft/lb (165Nm) @4250 rpm | M40B18 | 1987–1995 |
| 318iS | 1766cc | 4cyl | SOHC 8V | Petrol | 140hp (104kW) @4500 rpm | 127ft/lb (172Nm) @4250 rpm | M42B18 | 1989–1991 |
| 320i | 1766cc | 6cyl | SOHC 12V | Petrol | 123hp (92kW) @4500 rpm | 0ft/lb (0Nm) @4250 rpm | M20B20 | 1982–1985 |
| 320i | 1766cc | 6cyl | SOHC 12V | Petrol | 127hp (95kW) @4500 rpm | 0ft/lb (0Nm) @4250 rpm | M20B20 | 1985–1991 |
| 320is | 1990cc | 4cyl | DOHC 16V | Petrol | 192hp (143kW) @4500 rpm | 155ft/lb (210Nm) @4250 rpm | S14 | 1982–1990 |
| 323i | 1766cc | 6cyl | SOHC 12V | Petrol | 139-150hp (104-110kW) @4500 rpm | 0ft/lb (0Nm) @4250 rpm | M20B23 | 1982–19850 |
| 325e | 1766cc | 6cyl | SOHC 12V | Petrol | 101hp (75kW) @4500 rpm | 103ft/lb (140Nm) @4250 rpm | M20B16 | 1982–1990 |
| 325i | 1766cc | 6cyl | SOHC 12V | Petrol | 101hp (75kW) @4500 rpm | 103ft/lb (140Nm) @4250 rpm | M20B25 | 1982–1990 |
| 325iX | 1766cc | 6cyl | SOHC 12V | Petrol | 101hp (75kW) @4500 rpm | 103ft/lb (140Nm) @4250 rpm | M20B16 | 1982–1990 |
| M3 | 2302cc | 4cyl | DOHC 16V | Petrol | 197hp (147kW) @4500 rpm | 0ft/lb (0Nm) @4250 rpm | S14 | 1986–1988 |
| M3 | 2302cc | 4cyl | DOHC 16V | Petrol | 212hp (158kW) @4500 rpm | 0ft/lb (0Nm) @4250 rpm | S14 | 1989–1991 |
| M3 Evolution | 2302cc | 4cyl | DOHC 16V | Petrol | 197hp (147kW) @4500 rpm | 0ft/lb (0Nm) @4250 rpm | S14 | 1987–1987 |
| M3 Evolution II | 2302cc | 4cyl | DOHC 16V | Petrol | 217hp (162kW) @4500 rpm | 0ft/lb (0Nm) @4250 rpm | S14 | 1988–1988 |
| M3 Sport Evolution | 2467cc | 4cyl | DOHC 16V | Petrol | 235hp (175kW) @4500 rpm | 0ft/lb (0Nm) @4250 rpm | S14 | 1990–1990 |
| 324d | 2443cc | 6cyl | SOHC 12V | Diesel | 84hp (63kW) @4600 rpm | 112ft/lb (152Nm) @2400 rpm | M21D24 | 1985–1993 |
| 324td | 2443cc | 6cyl | SOHC 12V | Diesel | 114hp (85kW) @4800 rpm | 162ft/lb (220Nm) @2400 rpm | M21D24 | 1985–1993 |
Engine Swaps
M50 and M52 M30
Uploading images and files
To upload you'll need to sign-up. See the top right corner if you haven't already created an account.
Once logged in you will see the toolbox in the left panel has an Upload file link. You can use this to upload images for you pages.
To use an image in a page just use
[[Image:Filename.jpg]]
Please note filenames are also case sensitive.
Formatting
This page details the guidelines for how to edit pages on the zone wiki.
A great list of simple formatting options is on the Wikipedia site here: Wikipedia Cheatsheet
For pages that are incomplete please add the stub template by placing the following text at the start of your article:
{{stub}}
This will ensure that it's easy for users to find and update articles that need updating.
Tables
{| class="wikitable"
|+'''Table Title'''
|'''First Column Header'''
|'''Second Column Header'''
|'''Third Column Header'''
|We
|Love
|E30s
|Old
|Skool
|Cool
This should look like:
| First Column Header | Second Column Header | Third Column Header |
| We | Love | E30s |
| Old | Skool | Cool |
