Engine Swap - M6x
Revision as of 19:46, 10 April 2013 by Grrrmachine (talk | contribs)
Parts List
Engine
Left side engine mount
Therefore the engine options are:
Right side engine mount
Mounts
Oil Filter
Remote oil filter
There are three gearboxes to choose from; either a 5- or 6-speed manual gearbox, or an automatic. The choice is entirely up to you, but what you buy will directly affect which differential you use. To explain; the auto box on an E32 730i V8 is a 5 speed, the A5S310Z with the 0.74 overdrive fifth. In comparison, a five speed manual V8 box has a direct drive non overdrive fifth so you'll need a nice tall diff to cope - a 3.25 M3 diff will be ideal. The six speed units on the 540i and 840i used the same ratios but with an overdrive sixth which will allow for a lower ratio diff.
Propshaft
Custom prop for 6-speed box
Gear Selector
Fan
Temp Switch
Exhaust
Manifold
Exhaust Pipes
EWS
Main article: EWS
Temp Sensor
