Engine Swap - M6x
Parts List
- Engine mounts
- Complete engine loom
- Gearbox
- Clutch
- Propshaft
- Differential
- Exhaust including manifolds
- Fan
- Radiator
- Gear bridge
- Brake servo
Engine
Therefore the engine options are:
Mounts
Oil Filter
Propshaft
Gear Selector
Fan
Temp Switch
Exhaust
Manifold
Exhaust Pipes
EWS
Main article: EWS
Temp Sensor
