S5x
The BMW S5x range of engines are a line of 6-cylinder engines, fitted to BMW Motorsport models between 1992 and 2001. The range is comprised of two main units; the S50 and the S52. All S5x engines are fundamentally based on the M5x series of engines that powered the E34 M5 and E36 M3, and are therefore very popular engine swaps.
S50
The S50 engine first saw action under the bonnet of the E34 and E36 as the 3.0 variant, before being enlarged to 3.2 in 1995. These phenomenal engines were complete rebuilds of M50 engines; the blocks had a wider bore, the crank had a longer stroke and the whole compression was raised to 11.8:1. Compared to the simple 24V head of the M50, these engines featured Double [M5x#VANOS|VANOS]] technology and independent throttle bodies (six in all) to guarantee
S50 engines weigh 138kg
| S50B30 | 3.0 L (2990 cc/182 in³) | 210 kW (282 hp) @ 7000 | 320 N·m (236 ft·lbf) @ 3600 | 7200 | 86mm | 86mm | 1992 |
| S50B32 | 3.2 L (3201 cc/195 in³) | 236 kW (321 hp) @ 7400 | 350 N·m (258 ft·lbf) @ 3250 | 7600 | 86.4mm | 91mm | 1995 |
S50US
Unfortunately for the US market, the phenomenal performance of the S50 engine came at too high a cost, both in dollars and pollution. To import such an engine and tune it to meet stringent emissions regulations would put a standard M3 far above the price bracket at which it was marketed.
Rather than rebuilding the S50, BMW adapted the existing M50 design to offer a tuned engine that performance half way between. Power and torque output are significantly decreased in contrast to the "original" S50, but are a massive improvement on the M5x design. At 240hp, the S50B30US slots neatly between the M50B25 at 191hp, and the S50B30 at 282hp.
| S50B30US | 3.0 L (2990 cc/182 in³) | 177 kW (241 hp) @ 6000 | 305 N·m (225 ft·lbf) @ 4250 | 6500 | 86mm | 86mm | 1993 |
S52
S52 engines weigh 118kg
| S52B20 | 2.0 L (1990 cc/121 in³) | 110 kW (148 hp) @ 5900 | 190 N·m (140 ft·lbf) @ 4700 | 6500 | 80mm | 66mm | 1994 |
| S52B25 | 2.5 L (2494 cc/152 in³) | 123 kW (170 hp) @ 5500 | 245 N·m (181 ft·lbf) @ 3950 | 6500 | 84mm | 75mm | 1995 |
| S52B28 | 2.8 L (2793 cc/170 in³) | 142 kW (193 hp) @ 5300 | 280 N·m (207 ft·lbf) @ 3950 | 6500 | 84mm | 84mm | 1995 |
S52TU
| S52TUB20 | 2.0 L (1990 cc/121 in³) | 110 kW (148 hp) @ 5900 | 190 N·m (140 ft·lbf) @ 3500 | 6500 | 80mm | 66mm | 1998 |
| S52TUB25 | 2.5 L (2494 cc/152 in³) | 123 kW (170 hp) @ 5500 | 245 N·m (181 ft·lbf) @ 3500 | 6500 | 84mm | 75mm | 1998 |
| S52TUB28 | 2.8 L (2793 cc/170 in³) | 142 kW (193 hp) @ 5500 | 280 N·m (207 ft·lbf) @ 3500 | 6500 | 84mm | 84mm | 1998 |
