Steering
Revision as of 10:07, 10 March 2012 by Grrrmachine (talk | contribs)
Rack
Simple overview of Rack & Pinion Steering
Tie Rods
The tie rod is what connects the rack to the wheel hub. At the rack end the tie rod simply screws into the output shafts of the rack, and is then joined to the hub via a balljoint. The tie rod itself can be split in two leaving you with the outer part commonly known as the track rod end. The amount this is wound back into the tie rod is what affects the front wheel alignment.
PAS Pump
Steering Column
Steering Wheel
Main article: Steering Wheels
Vague Steering
Maintenance
Faster Rack
While the steering of an E30 is a charm of feedback-response, neither too heavy or too light, many of the more spirited drivers find the standard rack too long, in the sense that it takes too many turns from one full lock to the other. Fitting a faster rack from a BMW Z3 is a common and simple upgrade, but for those looking for bigger increases, fitting a rack from an E36 M3 can bring dramatic improvements.
