Steering
All E30's came with a Rack & Pinion steering configuration, this is a simple configuration found in most cars. The pinion gear sits on the end of the steering column/shaft which has the steering wheel at the other end, the pinion gear then turns as you turn the steering wheel which moves the rack lateraly causing the track rods to push/pull the wheels allowing the car to turn.
Simply put, the rack & pinion does two things, it converts the rotational motion of the steering wheel into the linear motion needed to turn the wheels and it provides a gear reduction making it easier to turn the wheels.
The E30 came with either Power Assisted Steering and non-Power Assisted Steering. PAS uses a hydraulic pump powered by a pulley driven via a belt attach to the crank pulley, this pumped fluid then drives a piston built into the rack to make it easier to turn the pinion gear.
Rack
As mentioned earlier, there is a PAS and non-PAS rack available for the E30 both forms are generally very reliable.
Tie Rods
The tie rod is what connects the rack to the wheel hub. At the rack end the tie rod simply screws into the output shafts of the rack, then it is joined to the hub via a balljoint. The tie rod itselft can be split in two leaving you with the outer part commonly known as the track rod end, the amount this is wound back into the tie rod is what affects the front wheel allignment.
PAS Pump
Steering Column
Steering Wheel
Main article: Steering Wheels
Vague Steering
Obviously with age and regular use the the rack mechanism can wear and introduce play to the steering, this can be seen by there being a delay from turning the steering wheel to the front wheels steering. However a more common issue for this feeling is the rubber guibo in the steering linkage having broken up meaning there is play in the linkage, you can either replace the rubber guibo with an OEM part or make a customer solid spacer.
Maintenance
Faster Rack
While the steering of an E30 is a charm of feedback-response, neither too heavy or too light, many of the more spirited drivers find the standard rack too long, in the sense that it takes too many turns from one full lock to the other. Fitting a faster rack from a BMW Z3 is a common and simple upgrade, but for those looking for bigger increases, fitting a rack from an E36 M3 can bring dramatic improvements.
