Converting to Motronic 1.3
Revision as of 14:50, 15 January 2012 by Grrrmachine (talk | contribs) (New page: Motronic 1.3 was introduced to E30s 1988 when the facelift cars were launched, and was the final version of the engine management system used on thes...)
Motronic 1.3 was introduced to E30s 1988 when the facelift cars were launched, and was the final version of the engine management system used on these cars. For those with older vehicles, it can be worthwhile stripping out your older system to fit Motronic 1.3. Here's why and how it's done.
Benefits
• Firstly going to the single crank pulley sensor is both easier to fault find with as there are less parts to go wrong and there is no TDC tab that have been known fall out of the flywheel. Is easier to access to replace.
• Improved accuracy of sensors and event timings for better engine running (fuelling and timing).
Sensors
Like all Motronic systems, 1.3 runs on a number of sensors, these are:
Sensor Location
Air Flow Meter Engine Bay
Intake Air Temperature sensor Built into the Air Flow Meter
Crank Position Sensor Front of engine block
Throttle Position Switch Under throttle body
Engine Temperature Sensor Engine head
Cylinder Identification Sensor Fitted to HT leads
Lambda Sensor - catalyzer-equipped vehicles only Exhaust downpipe
