Lights
Revision as of 17:40, 18 December 2011 by Grrrmachine (talk | contribs)
While it's often joked that these things don't exist on BMWs, the E30 is equipped with a variety of Lights to help you and other road users
All cars by law must be equipped with a number of lights to aid navigation and to give signals.
Headlights
Dipped
High Beam
Parking
Rear
Brake Lights
Reverse
Licence Plate
Indicators
The orange bits at each corner of your car are there to signal your intentions to other road users. They are called Indicators.
Side Repeaters
Hazards
Foglights
Front Fogs
Rear Fogs
Interior
Mirror Light
Instruments
Some basic candles are fitted to all E30s to help you read your Instruments at night. These lights will glow as soon as the Lights#Headlights are turned on, and their brightness can be controlled by turning the headlight knob clockwise or anti-clockwise.
Glove Box
HIDs
Tinting
Smoked Headlights
Tinted Rears
