Clutch Disc
The clutch disc
The output shaft of the gearbox is splined, and the clutch disc fits over these splines.
Pressure Plate
Release Bearing
Master Cylinder
Slave Cylinder
Common Problem
Pedal Feel
If your pedal is becoming either too hard or too soft, or the biting point is rising and falling, then it is very likely that either your Master or Slave cylinder is failing.
