Interior
Revision as of 17:56, 12 November 2011 by Grrrmachine (talk | contribs)
Dashboard
Instruments
Main article: Instruments
Controls
  • Wash/Wipe stalk
  • Indicator stalk
  • Cruise Control stalk - if fitted
  • OBC stalk - if fitted
  • Hazard Lights
  • Rear Wash/Wipe - Touring only
  • Heater Controls
  • Rear Demister
  • Air Conditioning - if fitted
  • Electric Windows - if fitted
  • Heated Seats - if fitted
Vents
Seats
The comfort point of the vehicle. All E30s were capable of seating 5 people, although the fifth passenger may be rather cramped, even in the Touring. The upholstery of the seats is one of the defining points of the interior, with seats available in cloth or leather in a number of colours.
Front Seats
Seat Belts
Rear Bench
Rear Seat Belts
Door Cards
Carpet
E30 Carpet
Headlining
Maintenance
Problems
