Revision as of 08:14, 20 October 2011 by Grrrmachine (talk | contribs)
Brake Pedal
Brake Servo
Master Cylinder
Brake Fluid
Brake Lines
Brake Hoses
Calipers
Discs
Pads
Drums
Cylinders
Shoes
Handbrake
ABS
Main article: ABS
Pulling to one side
Squealing
Main article: Brake Upgrades
Remember, bigger doesn't always mean better; massive discs with 4- or 6-pot callipers will add a massive amount of weight to your vehicle, especially its suspension, and you may have difficulty finding wheels that fit. It's often enough just to fit racing-spec pads and discs, and keep your system in top performance with regular servicing.
