M10
Revision as of 08:27, 8 October 2011 by Grrrmachine (talk | contribs)
The BMW M10 is a 4-cylinder engine, fitted to the 316 and 318 until 1987. It was replaced by the M40 as the standard 4-cylinder engine.
he engine was designed by noted engineer and race driver Baron Alex von Falkenhausen. He was asked to design a small-displacement (1.3 L) engine, but felt that this would be insufficient for the company's future needs. Therefore, he designed a block that could be expanded to 2.0 L and delivered it at 1.5 L. The design was very successful, with over 3.5 million produced, and it served the company for over 25 years.
The S14 engine for the M3 was based upon the M10 block. In the M3, the M10 block design is still winning races today.
Models
M10B16 1.6 L (1766 cc/97 in³) 89 hp (66 kW) @ 5500 103 ft·lbf (140 N·m) @ 4250 6200 1988
M10B18 1.8 L (1776 cc/109 in³) 105 hp (77 kW) @ 5800 107 ft·lbf (145 N·m) @ 4500 6200 1987
M10B16
The M10B16 is a 1.6 L (1766cc) version of the M10 producing 89hp and 103 ft.lb of torque using Pierburg 2BE carburettors.
The M10B16 was also fitted to the E28.
M10B18
The M10B18 is a 1.8 L (1766cc) version of the M10 producing 105hp and 107 lb.ft of torque using K-Jetronic fuel injection.
The M10B18 was also fitted to the E21, and briefly the E28 in 1984.
Characteristics
Engine Bay
Every engine needs its fluids and filters changed regularly. The M10 engine also needs its timing belt replaced at regular intervals. Learn more about changing the timing belt.
Won't Rev Over 5000
To confirm, remove the rocker cover and baffle plate so that you have access to the cam shaft, and run your finger nail over the cam lobes. If you can feel scatches, grooves or other imperfections, the cam is in bad condition.
The only solution is to replace.
Carburettor Upgrade
The Pierburg 2BE carburettor found in 316 models is not considered a particularly good carburettor. Converting to a Weber carburettor will yield more power and more tuning options. Learn more about Weber carburettors.
Useful websites
See also
