E30
If it was made by Carlsberg, they'd say it's probably the best car in the world. As it's made by BMW we know it IS the best car in the world.
Technical
Engines
- Main article: Engines
- Main article: Gearbox
- Main article: Differential
- Main article: Brakes
- Main article: Suspension
Steering
- Main article: Steering
Body Styles and Fittings
- Main article: Bodywork
Electrical
- Main article: Electrics
