Fitting E32 Master Cylinder
Revision as of 11:35, 25 January 2015 by Grrrmachine (talk | contribs)
If you've recently upgraded your brakes by fitting some E34 calipers, then you'll need a bigger master cylinder to push all that extra fluid around.
Here's how to install the Master Cylinder and servo from the mighty E32 7-series.
Parts
  • E32 735i Servo, Master Cylinder and Reservoir
Tools
  • 3/8 socket set
  • 11mm brake pipe spanner or combination if you don’t have one
  • Screwdrivers
  • Electric drill and bits up to 12mm
  • Carbide burrs
  • Grinder and discs
  • Tap and die set (M10x1.5)
  • Cutting oil (wd40)
  • Rags for keeping stuff clean
  • Some washers
Open the bonnet and undo the air intake boot by loosening the two jubilee clips and the ICV
Looking at the rear of the engine bay on UK nearside to see the servo setup
Undo the two brake pipes coming out of the MC with your 11mm spanner. Catch any fluid in a rag or bucket as fluid will pour out the MC and pipes
Remove the MC from the servo by undoing the two 13mm nuts (some people may not need to remove this from servo but I found with the space left by the M20 it looked easier)
Inside the car slide the passenger seat all the way back or remove completely if you want even more space (4x17mm)
Remove glove box using the two screws mounted to the bulkhead. Be prepared to find signs of Rust in your bulkhead.
You will now see the brake clevis and mechanism to turn the movement through 90 degrees.
Take the pin out of the clevis by removing the clip, but keep your hand round it as it will want to fire
off somewhere and not want to be found, the slide the pin out and keep it all safe
Following the push rod towards the bulkhead you will see a big black plate with 4 13mm nuts
Back to engine bay side and pull servo free from bulkhead and remove from the bay
Admire your gaping hole and repair any rust while this is out
Get the E32 servo and remove the spacer as this hinders clearance with the M20 intake boot
You’ll now see that there are only two studs to mount to the bulkhead, this is fine and it’s not exactly heavy
These two studs don’t fit in the standard holes so you can either drill some new ones a bit further
over or open up the holes already there, I voted for the later
Using a carbide burr I slotted the holes roughly 8mm towards the center
Test fit number one to see if it clears... IT DOES!
Look inside at where it bolts and you’ll see that the push rod is far too long and needs shortening a
lot
Remove the servo again and look at the rod, its a lot fatter than the thread so needs grinding down
so the die wont get stuck and snap something
30 seconds with a grinder and the shaft was small enough to work with
Wound on the die and sprayed loads of wd40 at the teeth as I started to make the new thread
I wont go into technique but If you’ve never tapped anything before then your best learning before
doing this as if you get it wrong it means buying a new servo
Thread it as far as you can, I held the rod in a pair of mole grips I clamped into a vice to stop the
shaft spinning and not cutting
Once its threaded its time to take it back to the car to see how much it needs shortening
Test fit number two
Attach your clevis to the mech and then place next to the noe fully threaded rod
This will tell you how much to take off, best to take too little than too much as you can always take a
little more bit by bit
Make sure your die is wound on past where your cutting before you cut it, this allows you to clean
the start of the thread after cutting it
Cut it off and then wind the die off
The clevis should now thread nicely onto the shortened rod
Take back to the car and fit again for third time 
If all is well you wont need to remove again so add a washer and bolt the servo to the bulkhead
The clevis can be adjusted to suit the brake mech and can also be adjusted to take any slack out of it
Leave the glovebox out for now until its all done as you may need to adjust little bits
Grab your new matching MC
Bench bleed it by filling the resivoiur of suitable dot rated fluid
Keeping the holes plugged with rags or your fingers install the MC to the servo and quickly put the
brake hard lines In, you will need to bend them to fit as the MC is now further away from the
bulkhead but its not hard or too far to bend them (if your really anal then make new ones but im on
a budget)
Bleed all the brakes starting from the furthest away from MC so OSR NSR OSF NSF
Test drive time
If any slack in the pedal then the clevis/brake rod can be adjusted
Once all is well and no leaks have appeared then install your glovebox and hopefully you’ll have
more braking assistace to match any caliper upgrade you’ve done.
With the E34 calipers on the front, and potentially bigger brakes on the rear as well, the standard E30 master cylinder isn't big enough to move enough fluid. To get around this, most people use the E32 750i MC but I also wanted more assistance to match. The 750i MC is also becoming increasingly expensive due to its rareity, so I'm opting to use a more mundane E32 735i MC and servo instead. This master cylinder is still 25mm, so should improve the feeling to near stock level
However, a few mods will be needed to make this fit.
The E32 I got mine from had a spacer on the back of the servo. There are two options here:
  1. Use the spacer. This requires the least mods but the brake fluid reservior will be right underneath the inlet boot on the M20 engine, and might not fit.
  2. Ditch the spacer, but make a few mods instead. This involves:
Grinding down and shortening the push rod to put the clevis at its original level Open up 2 holes in the bulkhead Bend the brake lines slightly
I choose number 2 for an original look to the engine bay
Start by opening up the mounting holes E34Brakes005
Grind down the pushrod E34Brakes006
Start making the thread using your die E34Brakes007
Cut about an inch and half cut off (37mm), and thread it as far as you dare E34Brakes008
Remember if you're doing this yourself then leave the die wound on before you cut the excess off. That way, you can then unwind it and clean the threads so that the clevis can go on with no trouble
test fit E34Brakes009
I was made up that the standard E32 vacuum line was in the perfect place to line up to the E30 system
The clevis is the trickiest part I lost the E30 clevis so I used the E32 one but it was way too long. This required trimming and slight mods so please keep your E30 one unless you want some trial and error fitment issues that involves installing and removing the servo/clevis multiple times E34Brakes010
All done apart from take it all apart to paint the servo and bench bleed the MC E34Brakes011
