Engine Swap - M6x
Revision as of 19:29, 10 April 2013 by Grrrmachine (talk | contribs)
Parts List
  • Full M6x Engine with all ancillaries (injectors, MAF, inlet, coil packs, alternator)
  • Engine mounts
  • Complete engine loom
  • Gearbox
  • Clutch
  • Propshaft
  • Differential
  • Exhaust including manifolds
  • Fan
  • Radiator
  • Universal Joint
  • Gear bridge
  • Brake servo
Engine
Left side engine mount
Right side engine mount
Mounts
Oil Filter
Remote oil filter
Propshaft
Custom prop for 6-speed box
Gear Selector
Fan
Temp Switch
Exhaust
Manifold
Exhaust Pipes
EWS
Main article: EWS
Temp Sensor
