Engine Swap - M6x
Parts List
- Engine mounts
- Complete engine loom
- Gearbox
- Clutch
- Propshaft
- Differential
- Exhaust including manifolds
- Fan
- Radiator
- Universal Joint
- Gear bridge
- Brake servo
Engine
Mounts
Oil Filter
You'll be wanting to keep your new engine in good condition, and that means regular servicing. But with the V8 wedged in place, you'll find it next to impossible to access the oil filter, which is why it's worth looking at relocating it using an external filter mount.
The 6-speed from the 540i offers a final gear, which provides a faster top speed if mated to the correct differential. However, it requires a custom propshaft to mate up to the differential; no standard solution is available.
You'll need the best possible clutch if you're going to make use of all that lovely lovely torque. Unfortunately, if you've opted to use a 5-speed gearbox then you can't use an off-the-shelf BMW clutch - you will have to contact a specialist clutch supplier. Helix can supply one if you ask nicely.
Propshaft
If you've chosen to use the 6-speed gearbox then you're committing yourself to a custom propshaft.
This needs to be chosen to match your gearbox.
These engines run hot, so you'll need a radiator that can cope. While the radiator from a donor E34 may be up to the job, its physical size won't fit between the chassis rails of an E30 so you'll have to resort to some butchering to make it fit. Far easier is to use a radiator from an E36 M3, or even a Z3 radiator. Either of these units will drop into place using the existing mounts. If you're really worried about your cooling potential, a thicker alloy unit can be bought from Mishmoto.
Exhaust
Manifold
Exhaust Pipes
EWS
Main article: EWS
Temp Sensor
