Lights
While it's often joked that these things don't exist on BMWs, the E30 is equipped with a variety of Lights to help you and other road users
All cars by law must be equipped with a number of lights to aid navigation and to give signals.
Headlights
While the high beam is essentially the same on all cars, three different light setups were installed on E30s during their production. The early cars featured a simple lamp setup that reflects the light from the bulb, making a dispersed glow in front of the car. Later cars were fitted with projection lenses, which focused the beam into a brighter, tighter area. They also contained a black cut-out to prevent light scattering upwards, and for this reason these later lights are known as "smileys".
For one year, 1988, a lamp was fitted that contained the projection lens but without the cutout. These lamps are known as "bullseyes", and offer the best light of all, for the driver at least. They're not so friendly to oncoming traffic.
Dipped
Bulb: H1 55W
The main driving lights are turned on by fulling pulling out the headlight switch.
High Beam
Bulb: H1 55W
Parking
Bulb:
Headlight Washers
Headlamp Adjusters
Rear
Two types of rear cluster were fitted during the lifetime of the E30, but they are interchangeable between all years and body styles.
For those that find the rear cluster not to their taste, a popular aftermarket alternative is available from MHW. If you can't fork out for replacement units, learn more about tinting your own lights.
Rear Lights
Bulb: 12V 10W
Brake Lights
Bulb:12V 21W BA15
Reverse
Bulb:
Licence Plate
Bulb: 12V 5W
Indicators
Bulb: 12V 21W BA15 (rear)
The orange bits at each corner of your car are there to signal your intentions to other road users. They are called Indicators.
Side Repeaters
Bulb:
Hazards
Foglights
Front Fogs
Bulb: H3 12V 55W
Rear Fogs
Bulb: 12V 21W
If you think you need rear fog lights, learn more about retrofitting rear fog lights.
Interior
Bulb:
Mirror Light
Instruments
Bulb: 12V 3W baseless (cluster) 12V 1.2W baseless (heater controls)
Some basic candles are fitted to all E30s to help you read your Instruments at night. These lights will glow as soon as the Lights#Headlights are turned on, and their brightness can be controlled by turning the headlight knob clockwise or anti-clockwise.
Glove Box
Bulb:
HIDs
Tinting
Smoked Headlights
Tinted Rears
