Installing VDO gauges
Gauges
Oil Temperature
The Audi Oil Temp gauge has a range of 0-170°C. VW gauges will show 0-150°C. It is also possible to find 0-120°C gauges; some will say Oel (oil) while others will show the standard Coolant image, but they are identical units underneath.
The oil temp gauge is driven by a single thermistor sender. This little unit looks like a bolt with a pin on top, and has no moving parts. Once screwed in and wired up, a basic current is passed through the sender, earthing through the engine. As the temperature rises, the sender's internal resistance is lowered, increasing the current and therefore increasing the power to the gauge. This makes the needle move more to one side, and therefore reading a higher temp. How simple. What's important is to use the right sender for the gauge, so here are the VDO part numbers to order the appropriate sender (if you haven't got it already):
| M10 x 1.0 | M12 x 1.5 | |
| 120°C | 049-919-563B | |
| 150°C | 323-804-006-005D or 323-804-006-006D | 323-801-010-003 |
| 170°C | 323-804-015-001D |
Oil Pressure
The Oil Pressure sender is the most significant part of the system, and should be a fat metal canister with a threaded bolt at the bottom and one or two pins at the top. These top pins will either be spade connectors or threaded posts with nuts; both can be used in your E30. If your sender has two top pins, it means you don't need the oil pressure switch which is currently fitted to your engine, since that function is built into your new sender.
The most important part is the pressure rating of your sender; on the side of the bottom bolt face should be a pressure rating; 0-5 or 0-10. It is essential that this matches the range of your pressure gauge. The sender part numbers are:
- 0-5 bar -
- 0-10 bar -
Volts
Some consider the Volt Gauge or Voltmeter to be filler; an extra dial to make the cockpit look more advanced, more technical. While it's certainly not as crucial for the engine as the Oil gauges, the Volt gauge is very important for assessing the health of your charging system, and lets you know how your alternator is doing, whether your battery is up to the job and whether you've got a serious power failure on your hands.
Unlike other gauges, the Volt gauge needs a simple connection to a switched 12V supply; there are no senders required to make the gauge work, and is therefore a very simple addition to the instruments.
Gauges
Tuning companies such as Hartge and Alpina offered additional pod units that sat on top of the dashboard; these were either extensions of the main instrument binacle, or standalone pods that sat on either in the centre or the passenger side of the dashboard. By placing the gauges on the same level as the other instruments, they gave the driver a more natural viewing position.
However, it is very hard to get hold of these pods, and aftermarket alternatives are of generally poor quality. They also necessitate drilling, cutting and gluing the dashboard, which is something you may be very reluctant to do.
Because of this, we recommend you choose one of these locations to fit your gauges. All three will necessitate a small amount of fabrication, but this can be done with standard plastic sheet rather than building your own gauge pod.
Top Air Vents: This is where Alpina mounted their infamous Digital Dash Unit. By popping out and blocking up these central vents, you will be able to mount up to four gauges, or keep one vent and fit two gauges.
Ashtray:
Under Heater Controls:
