Installing VDO gauges
Gauges
Oil Temperature
The Audi Oil Temp gauge has a range of 0-170°C. VW gauges will show 0-150°C. It is also possible to find 0-120°C gauges; some will say Oel (oil) while others will show the standard Coolant image, but they are identical units underneath.
The oil temp gauge is driven by a single thermistor sender. This little unit looks like a bolt with a pin on top, and has no moving parts. Once screwed in and wired up, a basic current is passed through the sender, earthing through the engine. As the temperature rises, the sender's internal resistance is lowered, increasing the current and therefore increasing the power to the gauge. This makes the needle move more to one side, and therefore reading a higher temp. How simple. What's important is to use the right sender for the gauge, so here are the VDO part numbers to order the appropriate sender (if you haven't got it already):
- 170°C - 049-919-563B
- 150°C - 323-804-006-005D or 323-804-006-006D
- 120°C - 323-804-015-001D
Oil Pressure
The Oil Pressure sender is the most significant part of the system, and should be a fat metal canister with a threaded bolt at the bottom and one or two pins at the top. These top pins will either be spade connectors or threaded posts with nuts; both can be used in your E30. If your sender has two top pins, it means you don't need the oil pressure switch which is currently fitted to your engine, since that function is built into your new sender.
The most important part is the pressure rating of your sender; on the side of the bottom bolt face should be a pressure rating; 0-5 or 0-10. It is essential that this matches the range of your pressure gauge. The sender part numbers are:
- 0-5 bar -
- 0-10 bar -
Volts
Some consider the Volt Gauge or Voltmeter to be filler; an extra dial to make the cockpit look more advanced, more technical. While it's certainly not as crucial for the engine as the Oil gauges, the Volt gauge is very important for assessing the health of your charging system, and lets you know how your alternator is doing, whether your battery is up to the job and whether you've got a serious power failure on your hands.
Unlike other gauges, the Volt gauge needs a simple connection to a switched 12V supply; there are no senders required to make the gauge work, and is therefore a very simple addition to the instruments.
Gauges
There are three standard locations for placing your gauges. Tuning companies such as Hartge offered
