320d ran out of fuel
chu346
Post Thu Apr 17, 2008 8:06 pm
A friend of a friends 320d or possibly 330d has ran out of fuel. They put some more in and cranked it over for about 25 minutes with a battery booster but not fuel is getting to the injectors.
Any ideas on what to try?
78dude
Post Thu Apr 17, 2008 8:20 pm
You should look into the Manual, I know modern Mercedes with a turbo diesel just need new diesel fuel and then just crank the engine to it starts after 20 seconds. Maybe you need to bleed the system for air before its starts....?
Post Thu Apr 17, 2008 9:48 pm
Running these dry is like a death wish, can f*ck the pump up
Cook318IS
Post Thu Apr 17, 2008 9:55 pm
i always thought that if you run out of diesel u need to bleed the system, always remeber from an episode of top gear winkeye
Jesus325iTouring
Frog freak !
Frog freak !
Post Fri Apr 18, 2008 12:15 am
Depends on the vehicle,some do,some don't,my works Transit for instance self bleeds,but a diesel Merc I had needed to be primed.
jbh
Hartge Crew
Post Fri Apr 18, 2008 12:18 am
losen the pipe on number one injector and turn it over till the fuel starts spitting out. thats what i had to do with my passat if it ever ran dry
stuartgallafant
Post Mon Apr 21, 2008 8:03 pm
jbh wrote:losen the pipe on number one injector and turn it over till the fuel starts spitting out. thats what i had to do with my passat if it ever ran dry
do you ralise how much work it is to get to the pipe?!
running out of fuel in these is bad, because it con fcuk the pump, but the system is clever enough to deal with air-locks (nothing too huge!!)
Sounds to me more like a pre-supply pump problem. There's a pump thats located next to the near-side chassis rail, under the rear passenger footwell that 'pre-supplies' the high-pressure pump with fuel. Check this is working. Its under a cover though, so get your 10mm and 8mm sockets out!
