ikram
No great problem changing the head gasket on an iron block 24 valve engine, although the alloy blocked versions can have problems with stripping threads and sinking liners (if fitted).
march109
Not the one on ebay from Christchurch is it?
As Brian said though depends on the material the engine is made from.
bebo
have u found a new engine or r u replacing the headgasket!
