M30 wont start, little help please!
JGG1
Back in an E30 !
Post Mon Apr 14, 2008 11:08 am
Right I bolted my m30 into my 325i touring (1988) last night, just connected the main loom, the battery, the engine earth, the ecu is in place as is the live feed to the power block next to it, the ignition lights are now fixed on and when you turn the key the starter just clicks!
Any ideas? Is it something glaringly obvious??! :cry:
jaffro
Post Mon Apr 14, 2008 11:09 am
are all the wires to the starter fastend tight??
Ziggy
Post Mon Apr 14, 2008 11:10 am
Power feed to the starter motor?
JGG1
Back in an E30 !
I didnt have any of them off as its still got all the 535 loom on it???
jaffro
Post Mon Apr 14, 2008 11:12 am
try tapping the starter? is battery fully charged?
JGG1
Back in an E30 !
Post Mon Apr 14, 2008 11:14 am
Not sure how much charge is in the battery tbh, I will go and check now and give the starter a crack, thing is if the starter was just stuck would that leave the ignition lights on all the time? Even when the key isn't in the ignition?? :mad:
johnl320
I'm sure we've been down this road before recently. Have you got a large wire going straight from the battery Pos to the large terminal on the starter solenoid?
john
JGG1
Back in an E30 !
Post Mon Apr 14, 2008 11:16 am
johnl320 wrote:I'm sure we've been down this road before recently. Have you got a large wire going straight from the battery Pos to the large terminal on the starter solenoid?
john
No!!
Ziggy
Post Mon Apr 14, 2008 11:18 am
Exactly the problem I had! :lol:
You need the starter motor power cable from your E30 - the M30 one's not long enough...
JGG1
Back in an E30 !
Post Mon Apr 14, 2008 11:19 am
Ideal!! Back in 10 minutes!! Cheers all!
Ziggy
jay1980 wrote:would that leave the ignition lights on all the time? Even when the key isn't in the ignition?? :mad:
Doesn't explain that though... :?
jaffro
Post Mon Apr 14, 2008 11:20 am
Ziggy wrote:Exactly the problem I had! :lol:
i sent you mine didnt i ziggy lol :P
sounds like thats the prob then :P
johnl320
Post Mon Apr 14, 2008 11:27 am
He's also got one of the earths that bolt onto the strut mount wired straight up to a battery pos. We'll tell him that onced he's torched the car 8O
john
JGG1
Back in an E30 !
Post Mon Apr 14, 2008 11:45 am
johnl320 wrote:He's also got one of the earths that bolt onto the strut mount wired straight up to a battery pos. We'll tell him that onced he's torched the car 8O
john
Me or ziggy???! 8O
Right its turning over now but theres no fuel, taken both the fuel and return pipes off, cranked it and there is definatly none getting to the engine??! Fuel pump not running??! :mad:
johnl320
Post Mon Apr 14, 2008 11:48 am
If your ignition lights are on even with the the ignition in the off position, worry about that first.
How many positive connections have you got going to the battery terminal?
john
JGG1
Back in an E30 !
Post Mon Apr 14, 2008 11:51 am
Seems to be 6, live feed to power block by ecu, live feed to starter, main wire to fuse box (incorporates 2 i think) then 2 more to inside the ecu main loom???
johnl320
Post Mon Apr 14, 2008 11:54 am
What colour are those last two ( you may need to peel back the black outer insulation)? Can you take a picture? have you got any earths going to the top of the strut mount?
john
JGG1
Back in an E30 !
Post Mon Apr 14, 2008 11:59 am
Cant get any pictures up as I'm at my bros. Right the wires are 2 in each, one set both brown, other set 1 brown/yellow the other brown/orange, got the main earth on from the strut top to negative.
JGG1
Back in an E30 !
Post Mon Apr 14, 2008 12:08 pm
Its alive!!!! Those last 2 wires john should have been to negative :o: so cheers for that!!
Nice and quiet with no exhaust!!!
Cheers all.
johnl320
Post Mon Apr 14, 2008 12:17 pm
No probs :D They sound awesome don't they 8)
Surely that would warrant a donation to my charity event below :wink:
JGG1
Back in an E30 !
Post Mon Apr 14, 2008 1:13 pm
johnl320 wrote:No probs :D They sound awesome don't they 8)
It certainly does mate, I will get straight on it when I get it!! :D
OBs
Post Mon Apr 14, 2008 1:19 pm
Now :ttiwwp:
OBs
JGG1
Back in an E30 !
Post Mon Apr 14, 2008 4:35 pm
OBs wrote::cool:
Now :ttiwwp:
OBs
I do have a proper build thread going with pictures, this was just a quick emergency thread!!!
