Hi - I am replacing the clocks in my e30, which I've done many times before ( SI boards, they're great ) but this time the top steering column shroud is stuck - I can't get it off>>?
The Haynes man says just rotate it up and lift it off....er....no! It's jammed solid...help!
cheers
Jim
Top steering column shroud is stuck?
- Brianmoooore
Top steering column shroud shouldn't come right off without loosening the whole dashboard - there's a lip at the back.
Why do you want to remove it to change the cluster?
- Brianmoooore
The fact remains that there's no need to remove any column shrouds or the steering wheel to remove the clocks!
danman2k
lol, i had to take mine out today and i used the bentley manual which says take the steering wheel offBrianmoooore wrote:The fact remains that there's no need to remove any column shrouds or the steering wheel to remove the clocks!
