single pipe exhaust system
foxie389
Post Mon Apr 07, 2008 7:49 pm
ive got to replace the exhaust on my track car and was thinking of saveing some weight at the same time.i was thinking of replaceing the twin system with a 3" single pipe system.possibly with only a single box .has anbody tried this and did it give any improvements?
UweM3
Post Mon Apr 07, 2008 8:21 pm
Pro:
it's chepaer
might be lighter as well
less fabrication work
Con's:
less ground clearance
single endpipe looks a bit naff (but that's only personal opinion)
doubt that there is a power gain (if two equally systems are compared)
Trise30rally
Post Wed Apr 09, 2008 2:43 pm
I have been thinking about doing this to my rally car, it will save a fair bit of weight.......
agreen
Post Wed Apr 09, 2008 2:52 pm
[quote="UweM3"]Pro:
Con's:
quote]
Need also to consider noise limits at uk track days.[/b]
e30_Turbo
Boost Junkie
Post Wed Apr 09, 2008 2:58 pm
I've done it, full 3 inch system, made it on the car, looks and sounds the NUTS!! if I do say so myself :cool:
Then again I have a few more CFM's coming out than most M20B25's :D
It made a HUGE difference to mine but not sure if that would be the same for N/A.
It's a single box system too, bloody backbox is tiny....... I'll see if I can find a picture.
e30_Turbo
Boost Junkie
Post Wed Apr 09, 2008 3:03 pm
There you go, I've still got the welding scars from that day, will never lean on a fresh weld again!
agreen
Post Wed Apr 09, 2008 3:04 pm
Nice.
DRIFTBOY
Post Wed Apr 09, 2008 3:31 pm
Depending what engine / spec you've got, I'd say 3" pipe could well be a little OTT! ?
Post Wed Apr 09, 2008 4:12 pm
3" is waaaaaay ott for a m20b25
2.25 is good to flow over 200bhp easy
UweM3
Post Thu Apr 10, 2008 6:48 am
fozzymonster wrote:Image
nice system. But you can't compare this to a NA engine. With a turbo your pipes can't be big enough :D and the noise level is different as well. The turbo acts like a silencer and therefore you get away with a much smaller silencer.
UweM3
Post Thu Apr 10, 2008 6:50 am
agreen wrote:
UweM3 wrote:Pro:
Con's:
quote]
Noise has nothing to do with single or twin pipe. Your silencer(s) needs to be large enough in either system to get the noise down.
zaust
Zone day release
Post Sun Apr 13, 2008 8:37 am
Done mine 4-5 years ago. Custom 2x3 into 1 and then 2 into 1 and straight through. never had a problem and sounds the nut's.
M30 Tech 1 Touring on gas.
fuzzy
He who sleeps with "Gingers"
Post Sun Apr 13, 2008 8:50 am
although my application is abviously different i have a single 3" straight through system from the turbo with one large rear silencer to keep the noise to a reasonable level. the problem mentioned about ground clearance is an issue but not overly so and handles most speedbumps without a problem but i have hit excessively high bumps causing damage in the past. i still have twin tailpipes sticking out the back of the box
ed325i
Post Sun Apr 13, 2008 8:52 pm
foxie389
Post Mon Apr 21, 2008 9:02 pm
was looking at an exhaust catalogue in my local motor factors and noticed a 318is exhaustis quite a large diameter and single pipe with a small back box.my question is,
i was thinking if i replace the centre box with a 2 into 1 y piece and run with a perfomance back box.what diameter is the standard 318 exhaust and will removing the centre box affect the cylinder scaveging.cheers
ed325i
Post Fri May 23, 2008 7:48 pm
I have gone for 2.5" single pipe.
JungleGus
Post Fri May 23, 2008 9:57 pm
3" is way way too big for an n/a m20 - go 2.25 - otherwise you lose flow. even 2.5 is quite big and IMHO you lose torque
djs325
Post Sun May 25, 2008 2:45 am
2.5" Single on my E30 325i with BTB Extractors.
michealewk
Post Sun May 25, 2008 11:01 pm
i have just taken off a single pipe exhaust didnt like the sound but i think the car was slightly sharper with the single pipe than the twin
pipe
TVRTASMIN
Post Sat Jun 14, 2008 9:35 am
The twin system on a straight 6 cylinder will give you better torque and mid range. Turbo needs one big pipe.
I'd use two twin silencers of the straight through variety with 2 x 1 3/4" pipes from the primaries.
