more 318 questions
AndyBird
Post Tue May 31, 2005 9:28 pm
right checked the rotor arm, cleaned the AFM and throttle body found a vacuum leak and sorted. but still running rough on idle and light throttle
what are the sparkplug gaps? maybe these are slightly out?
theres a vacuum hose from the throttle body which is just blocked off dont know where its supposed to go? also there is a plug on the wire that goes to the afm which is not used
cheers all
AndyBird
Post Wed Jun 01, 2005 10:17 am
anyone?
Gwynleym10
Post Wed Jun 01, 2005 10:30 am
What year is it for starters? M10 or m40?
The loose vacuum tube and the AFM cable sound a bit dogdy though....
Dual wheel carriers -------195litre Fuel Tank
London 2 Cape Town
www.Overlandinthesun.com
AndyBird
Post Wed Jun 01, 2005 11:21 am
is a 89 so a M40 as you look at the inlet from the passenger side the vacuum hose is on the right hand side of the throttle plate, i currently have this blocked up.
The plug is on the loom which goes to the AFM only
Gwynleym10
Post Wed Jun 01, 2005 11:47 am
Sorry i have no clue about the m40, have you tried looking at the diagrams on the ETK? might help to see where things should go.
ETK link below
http://www.realoem.com/bmw/select.do
London 2 Cape Town
