se side skirts
vendetta
Post Thu Apr 03, 2008 7:20 pm
mine have just turned up today has anyone got any fitting destructions or pics cheers :cool:
Post Sat Apr 05, 2008 6:29 pm
could be wrong but i think you need the clips and they just clip on ??????? :?
liam012
Post Fri Apr 18, 2008 10:40 am
There are two methods - drill for oem clips or use a bond to glue them on.
If you decide to do it properly with the clips some people have used a 5.7mm dril bit and some have used an 8mm drill bit to make the holes for the clips. not sure why but just check yourself the size of your clips and drill into some scrap metal to test the size needed.
if you are drilling follow up with a zinc rich paint to protect.
i also reccomend cleaning and waxoyling everywhere that will be covered by the skirts as they will become a dirt trap.
if you search for fitting skirts in the search of the site and check the "search for all terms" radio buttons you wiull find the same info.
i just got skirts from the dealer and needed to know how to fit em so i used the sesrch...
http://www.e30zone.net/modules.php?name ... ing+skirts
