Quick M50 gearbox mount question
EOS
Post Tue Apr 01, 2008 8:55 pm
Just a quickie really, what hanger and rubber mounts do you use?
Im sure I had the standard E30 gearbox hanger bit and normal mounts on my coupe and that worked fine.
Just went to bolt it up to the 4 door beast and the gear selector rods touch the prop donut, so im guessing i should be using flatter rubber mounts to drop it down a little bit?
Can't remember what i used last time.
Ant
Retired Team Member
Retired Team Member
Post Tue Apr 01, 2008 8:58 pm
E30 unit with M40 mounts is what I used last with the M50 type ZF box dude.
no issues with the selector rod assy, although the 2.8 Z3 lever would be a little close for comfort I rekon .
if in doubt give the rod a "swerve" to ease it up and over the obstruction
Post Tue Apr 01, 2008 8:59 pm
EOS
Post Tue Apr 01, 2008 9:15 pm
I thought it was.
I've just moved the whole lot over from a coupe to a saloon and now the selectors rubbing the donut.
Crazy car. lol
ed325i
Post Wed Apr 02, 2008 11:49 am
What prop are you going to use with the m50 box?
EOS
Post Wed Apr 02, 2008 12:55 pm
Z3 coupe front half and E36 328 auto rear.
EOS
Post Wed Apr 02, 2008 12:56 pm
The setups already been running in the coupe so everything should pretty much swap over to my 4 door beasty.
Laimis
Post Wed Apr 02, 2008 8:39 pm
ed325i wrote:What prop are you going to use with the m50 box?
325e/324td prop-shaft fits perfectly. it was done zillion times in my country.
Also with some small modifications e36 328 or similar shaft fits OK too.
BMW 325i '90
BMW 325iX Touring '89
BMW 524td '89
Post Wed Apr 02, 2008 9:59 pm
Laimis wrote: 325e/324td prop-shaft fits perfectly. it was done zillion times in my country.
Not exactly common props in this country
Yaninnya
Post Thu Apr 03, 2008 6:54 am
Laimis wrote:it was done zillion times in my country.
What is your country?
Jan
EOS
Post Thu Apr 03, 2008 7:31 am
I sorted it in the end I was having a special moment. It was the last job of the day and was too tired to think properly lol.
Plus my mate was been a special one in the car, as I told him to put it in neutral so I could attach the rod but instead he had it in 3rd so the throw was 180 degrees out, so when i turned it round and put the rod back on all was well and theres loads of clearance now. I don't know if he though i had a sequential box or something cause it only went back and forward the first time lol.
