yet another abs problem!!
Guest
Post Mon May 30, 2005 3:15 pm
Hi all. No abs light, although bulb working. Braked hard a few times and found the only wheel locking up is my n/s/r. This became more apparent the harder I stomped! Would 1 faulty sensor prevent the light from appearing? Is it likely to be the sensor? How easy is it to fix? Thanx all
TOURINGDADDY
Post Mon May 30, 2005 6:46 pm
If u had a faulty sensor the light would b on constant the only thing that will cause no light to come on and the wheel to lock up is a pump problem
