Fuel Filter
mattsbmw
Wed Mar 26, 2008 9:30 pm
Can anyone tell me where the Fuel filter is on a 1988 E30 325i and how i change it safely.
thanks
Yaninnya
Wed Mar 26, 2008 9:34 pm
It is on front ot the tank (on the left side), under the car.
How to change it safely? Don't smoke during the work. :wink:
Jan
fuzzy
He who sleeps with "Gingers"
should be under the floor on the passenger side below the front seat, in line , couple of jubilee clips job done but be aware of the flow direction indicated by an arrow on the filter.
Gwynleym10
Wed Mar 26, 2008 10:45 pm
Make sure you de- pressurise the system first. Have the engine running and take either the fuel pump relay out or the fuse ( I think fuse 16). If you don't you will waste a load of fuel..
Dual wheel carriers -------195litre Fuel Tank
London 2 Cape Town
www.Overlandinthesun.com
mattsbmw
fuzzy wrote:should be under the floor on the passenger side below the front seat, in line , couple of jubilee clips job done but be aware of the flow direction indicated by an arrow on the filter.
This is me being a bit thick, so is it underneath the car or under the passenger seat.
irish320i
Wed Mar 26, 2008 10:48 pm
Its under the car and it is better to remove the fuse or really as you ll end up sprayed in petrol it you dont
Cheers Alan
Al
89 316i s50b30, 00 subaru imperza turbo(gone) 2005 range rover td6,
danman2k
Wed Mar 26, 2008 10:52 pm
i did mine on the weekend, i have same car. start engine and remove fuse 11, let engine cut out and replace the fuse. it will cut off the pump and in turn the fuel. the pump is underneath the car, back passenger door. there is probably a black cover over it that needs removing. :)
Geoff
Thu Mar 27, 2008 12:17 am
Or you could always get a pair of mole grips and clamp the hose. I did that when i replaced mine. Spilt a splash of fuel agreed but did neither of the above suggestions. I guess there are many ways to skin a cat huh!
Good luck dude. :cool:
TRANSPORTER
Thu Mar 27, 2008 10:18 am
take out fuse 11 and start the car, it will run for max of 5 secs then cut out, although I wouldnt put the fuse back in until I had finished the work. Just in case.
THERE ARE AIMERS, USERS, MOTORISTS AND THEN DRIVERS
AlexBaur325
Thu Mar 27, 2008 12:15 pm
Is it in the same place on a facelift B20 car?
beemerbird
Fri Apr 11, 2008 1:16 am
In my 89 325 it's under the brake fluid resevoir. Fuse out, run the engine till it dies, battery neutral off, change it, then wonder why you haven't worked on your own engine before! :D
Fri Apr 11, 2008 9:28 am
beemerbird wrote:In my 89 325 it's under the brake fluid resevoir. Fuse out, run the engine till it dies, battery neutral off, change it, then wonder why you haven't worked on your own engine before! :D
Same here ( I Think ! ) bolted to the suspension strut on the passenger side - need to remove the airbox to get at it properly and its still a bit of a pig to remove - out of my 4 E30's don't think any of them had the fuel filter under the car - they've all been mounted in the engine bay !
mattsbmw
Fri Apr 11, 2008 12:33 pm
Thanks for this, will have a look this afternoon and see if i can locate it.
thanks
