cleaning help - Tree Sap!!!!
Wilson
Post Sat May 28, 2005 6:13 am
Cheap 325i I bought has been parked under a tree for 6 months and is covered in tree sap, car is black so not really noticable unless close up, but if you run your hands over the body work you can feel it!!
Any advise on getting this off without literally picking it of???
T cut doesn;t really work!
Marc
TOURINGDADDY
Post Sat May 28, 2005 8:01 am
U need a mop mate and a delecate hand or u'll go stright through to the primer/metal and a bottle of g3 and to get an ultimate finish a botttle of gold top also 4 the mop :D
japcarkiller
Post Sat May 28, 2005 9:21 am
same problem where i live. i used a polish called mer to get rid of it. works a treat.
The Scumball.1000miles 1000minutes £1000 car
WWW.SCUMBALL.CO.UK
clicky clicky
Borderbmw
Post Sat May 28, 2005 9:40 am
To clean it off without having to go to mopping etc,Autoglym fastglass is pretty good for getting sap,bird cack etc off (as is their tar remover) ive found it good for getting sap,tar,shite etc off :mrgreen:
Ritchie
Post Sat May 28, 2005 9:45 am
You can get stuff from Meguirs call Quik Clay which is meant to take it off. You spray the stuff on and then you rub the block of special clay over the paint. I tried it and didnt really like it but ive heard some people rave about it. Maybe i didnt use it properly?
Wilson
Post Sat May 28, 2005 10:57 am
Thanks guys, I've already got some mer so will try that first...!!, then will try each of the things you've all said.
Wilson
