Gearbox!!
sniffmydiff
Post Thu Mar 13, 2008 11:13 pm
hi i have a 1987 325i sport, im changeing it to a e34 525i m50 engine, will this bolt on to my gearbox, if so what flywheel & clutch do i use. thanks
suzie650
Post Thu Mar 13, 2008 11:40 pm
Yes it will, but you will have to twist the linkage slightly (the e34 box has got the same bolt pattern, but runs at something like 15° more.
Both flywheel fit, but I'd keep your current one as it is muich lighter. In this case, you also need to keep the e30 starter motor.
jmc330i
Post Fri Mar 14, 2008 12:37 am
I know the M20 flywheel bolts up ok, but doesnt it need some machining to fit the M50?
James
'91 325i Sport
'93 318i touring 16v
march109
Post Fri Mar 14, 2008 12:40 am
6-7mm off the face IIRC
EDIT 6mm according to my notes.
suzie650
Post Fri Mar 14, 2008 1:29 am
It seems to depend. I know ofM20 flywheel that fitted straight away. And if they dont, you can grind a little bit off the bloc casting / bolts that are in the way - No problem at all and easier than machining a flywheel (no need for balancing)
sniffmydiff
Post Fri Mar 14, 2008 2:18 pm
my e34 engine is a auto that wont make any differance, also looking & buying a Exhaust system & coilover what the best to get as im worryied about it restricting the m50 as e30 scorpions etc.. look abit small bore.
