Spacer Help Please....!
Zizzle
Post Thu Mar 13, 2008 10:37 pm
Im looking at set of rims but a bit unsure about the fitament....
Sizes are as follows
9x17 ET15 & 10X17 ET -15
What spacers will i need for them to fit onto a standard 325i cab... alignment aint a problem as my arches have been cut out for widening so NO clearence issues... I just want a wide meaty look!!
If these wont fit these are my second choice any help will be appreciated
8 x 16 ET 11 & 10 x 16 ET 11
Thanks... also whats the standard offset for e30s?
deepak
Post Mon Mar 17, 2008 10:23 pm
i wouldnt think you would need spacers as those 17s are wide and have low offsets anyway, they will look wide and meaty, you may only need thin spacers on the front but they are minor issues. the offsets on e30s are generally 15 - 25. the 17s should run fine if your cab aint lowered, hope this helps
