intermittent holding back
blueoval
Thu May 26, 2005 9:54 pm
hi all my first post,car e30 m40 engine 1989 1.8i ,problem is driving at any speed the car holds back as if the fuel or electrics are turned off take foot of the gas all ok, foot back on gas holding back starts again ,foot on gas while holding back i can accelerate through the holding back and car runs ok ,this happenscompletely at random,when this problem happens the whole car shudders,any one had the same problen orpossible cause. regards steve
Thu May 26, 2005 9:56 pm
the car been serviced? Fuel filter renewed? plugs all ok? Dizzy/rotor fine?
dazzy
Thu May 26, 2005 10:37 pm
have the same problem with my 2.5 m20 changed everything but fuel filter so will try that this weekend. does your rev counter die aswell?
Andy_magic
Thu May 26, 2005 11:38 pm
If your rev counter is dying it would suggest to me an electrical fault of some sort.
It the crank position sensor Ok, maybe loose.
Martinaston
Fri May 27, 2005 1:02 am
sounds like the blue temperature sensor next to thermostat if it's the M40.
