MED Front top mount group buy
Enter a group buy or look here for zone discounts
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Wed Mar 05, 2008 12:34 am
Hi guys,
I wanted to invest in a set of these myself so I asked the guy about a group buy.
The mounts themselves are a full mount including bearings, they are on slide adjusters and depending on ride height will give in the region of -3deg camber. As the bearing housing is on a thread they also give fine tuning of ride height.
[img]http://www.motorsportengineering.co.uk/ ... 28.gif[img]
That's the picture from their site.
Prices come in as a group buy of 10 to 15 pairs: £217.30 per pair delivered.
1. Hoshy
2.
3.
You know what to do :)
I'm going to let this run for 2/3 weeks and then place my order regardless. There's nothing in this for me except a slightly cheaper set of top mounts, payments will be made directly to MED.
:thumb:
Hoshy.
Post Thu Mar 06, 2008 6:21 pm
agreen
Post Thu Mar 06, 2008 6:33 pm
Any reason why you did not go for the eibach ones matey
I can get them at a very good price
-3.5 degrees neg camber 8)
or the intrax ones which are also very cool
Just wondering, not having a go or anything mate.
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Thu Mar 06, 2008 11:43 pm
Cheers Jhonno - and to think, I work in IT :mad:
Aaron - These are about 30quid less than the advertised eibach price and you get height adjustability too.
agreen
Post Fri Mar 07, 2008 12:45 am
ok cool
JimmyC
Post Mon Mar 10, 2008 5:36 pm
Are they supplying base plates to go ontop of the turrets?
Interested if so
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Mon Mar 10, 2008 7:32 pm
Not sure what you mean exactly Jimmy. Afaik it works as a complete replacement for the oem mounts.
JimmyC
Post Tue Mar 11, 2008 8:48 am
You can mount them under the turrets and get a small amount of camber adjustment, or mount them on top of the turrets to get a worthwhile amount of adjustment
They are only any good for me (after 4/5 deg neg) if I can mount them ontop of the turrret
To do so you need a base plate that sits between them and the turret, MED supply mosley and mosley supply these with the base plate. If MED can supply complete with the base plate then i'm interested
Hope thats not too garbled??
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Tue Mar 11, 2008 2:22 pm
Ok. Got an answer from Bill. In short, yes.
Stright from the horse's mouth: "yes med 1228 is supplied with fitting ring with bolts to fit to top mount which sandwich the inner wing."
