E34 M50 spark plug change.
Jesus325iTouring
Frog freak !
Frog freak !
Post Sun Mar 02, 2008 4:59 pm
Is there anything difficult about this job?
Next door says it was confusing and has given up, i've not looked yet,can't be that difficult,can it?
It's the 2L boat anchor if it makes any difference.
irish320i
Post Sun Mar 02, 2008 5:05 pm
really easy but if hes used to leads a bit odd 6 seperate coil packs are bolted down on top of the plugs
take the cover of the top and theres 2 10 mm nuts holding each coil pack you will also have to disconnect the plug going onto the coil pack very easy to do
Alan
Al
89 316i s50b30, 00 subaru imperza turbo(gone) 2005 range rover td6,
Jesus325iTouring
Frog freak !
Frog freak !
Post Sun Mar 02, 2008 5:10 pm
Thankyou Alan,I can go change them now pretending I already knew exactly what to do :D
Thanks again :wink:
irish320i
Post Sun Mar 02, 2008 5:42 pm
no hassle hope it goes ok
Al
