M3 rocker gasket and a few bit
Looking for genuine BMW parts at discounted prices? Try here!
irish320i
Post Wed Feb 20, 2008 9:00 pm
Hi paul got the short shift and brake seal kits no hassle looking for some prices fo a few more bits
s50b30 ea66678 is the last 7 digits of the car it came out of
Cam Cover gaskets including the ones round the plug holes
blanking plate and gasket from the South African spec S50. The part number for the plate is 11 72 1 402 416 referred to as a 'cover lid' in the ETK and The gasket is 11721318467 think there the right numbers got them of a post a while ago
Pair of E36 rear gearbox rubber mounts
exhaust gasket manifold to exhaust
engine mount rubbers - e28 M5
think thats t for now cheers
Alan
zimmerbimmer1
BMW Parts Meister
Post Thu Feb 21, 2008 5:10 pm
Hi Alan
Prices as follows
Cam cover Gasket inc plug hole gaskets £31.77
Blanking plate and gasket £6.99
Gearbox Mtgs £14.57 (pair)
Exh Man/exh gaskets £13.03 pair
Engine Mtgs £49.19 pair
Carraige £20
:D :D
irish320i
Post Thu Feb 21, 2008 5:51 pm
Thats cool will give you a call tommorow to order that stuff
Cheers Alan
Al
89 316i s50b30, 00 subaru imperza turbo(gone) 2005 range rover td6,
irish320i
Post Thu Feb 21, 2008 7:27 pm
sorry to add more but while im getting it posted i might aswell get a few more bits
Front Wishbone Rear Bush's m3 ones
is the bonnet insulation still availible
a couple of oil filters for the m3 engine
2 x 34411158421 should be handbrake cabbles
rigid brake lines for rear arms with disks
Cheers Alan
Al
zimmerbimmer1
BMW Parts Meister
Post Fri Feb 22, 2008 12:11 pm
M3 Bush's £17.02
Bonnet insulation £24.59 need to know year of car
and due to size of this carraige would go up to £50
Oil Filters £7.03 each
h/brake Cables £31.58 pair
Rigid brake lines £14.81 (for 4)
