bulbs in dash??
billgatese30
how easy is it to replace bulbs in the binnacle (with the speedo and tach in), the oil pressure bulb has gone and seeing as it is pretty important i better replace it. is it a bitch of a job to do or what??
dazleeds
- old skool raver
take pod out ant twist mate easy
just a shame theres so many screws holding it in lol
www.oldskoolfantasy.co.uk
Davenotouring
Not too bad, can be done in about ten mins.
Need to take off the long thin plastic panel above where the top steering column cown disappears.
The panel above your knees will need to come off to do this.
Then you will see the various screws needed to be undone to remove it. Top and bottom. You will pull off the plastic surround first by undo four screws.
BMW 328i Cab - Daily Slag
nav786
very simple mate. takes 10 mins
FOR SALE
SONY PSP'S £100
LOOPYLEE1965
billgatese30
cool, anyone know where is the best place to get the coreect bulbs??
BMW perhaps.
BMW perhaps.
Andy_magic
A dealer will be easiest as you wont have to rip the dash open, take out the bulbs then re assemble it and get the bulbs from a motor factor and then do it all again.
Unless someone can give the name of the right type of bulb and wattage....
LOOPYLEE1965
Andy_magic
I think they are 3 watt push ins with no metal ends, just a U shaped glass end with wire wrapped over the ends.
I THINK!
I THINK!
LOOPYLEE1965
It's possible (just) to replace some of the lamps by reaching up underneath after just removing the panel above the driver's legs.
LOOPYLEE1965
i think ill try that next time m8 good tip i broke the small panel dave was on about above thats how i found the two nunts behind it ( well one after the one i lostBrianmoooore wrote:It's possible (just) to replace some of the lamps by reaching up underneath after just removing the panel above the driver's legs.
Daryll
I managed to do it and it was pretty easy even for a muppet like me. I removed the steering wheel for added easiness as well.
although I did manage to snap my cluster bezel
@e30_daryll
