m50 engine swap. help please.
rolo_e30
iv got a full E30 325i and a full E36 325i,
have i got everything there to put the E36 engine straight in the E30 and drive it?
cheers, George.
cheers, George.
No
You need an engine crane
you will need the sump from an E34 525 with the M50 engine
rolo_e30
^^ and a couple of tools, hahaha
is that all i will need then a sump?
what about the prop shaft, will that all bolt straight up good?
ian332isport
Nope, you'll also need a load of research.rolo_e30 wrote: is that all i will need then a sump?
Here: http://www.e30zone.net/modules.php?name ... pic&t=6676ian332isport wrote:Nope, you'll also need a load of research.rolo_e30 wrote: is that all i will need then a sump?
Hope you've got an hour or two spare!
rolo_e30
cant be arsed reading all that, can anyone just give me a list of bits n bobs that i will need.
sorry to sound like a dick, but i get bad head ache's when i look a computer screen for to long.
resurch my arse, just bang it in and figure it out, hahaha
cheers, George.
cheers, George.
You can lead a horse to water................
Apart from you will need an E34 M50 sump and oil pick up, there's no one way of doing it, so you'll just have to have a few aspirin on standby, and get reading.
rolo_e30
yes.. but can you RIDE a horse to water??? hahaha
i dont think anyone knows whats what, im just going to drop the engine in and go from there.
its only nuts n bolts at the end of the day, and if you'v got a grinder, welder and a big hammer.........
cheers for all your help guys, il let you all know when its done.
bigun
mush these blokes on here give the best advice around go for it and we will all have a wager on when you ask the next question hahaha
blitz877
- AKA ajm-e30
read the link mate as it will make the job and your life much easier whilst doing the conversion
TBH, that's how I did mine. Did it before I found this place, so everything was done by trial and error!rolo_e30 wrote: im just going to drop the engine in and go from there.
