Hi , i m after a std m3 suspensions settings
, i ve just fitted eccrentic wish bone bushs and may later fit the m3 top mounts
and want to set the front suspension to m3 spec , any one got them ?
M3 SUSPENSION SETTING
Yes please I
i would like the full set front and back if poss
Caster and Steering Axis Inclination + rear setting if poss
many thanks
many thanks
E30Mark
Hmm there seems to be some discrepancies between my data and yours Henry, unless I'm converting minutes / seconds to degrees incorrectly!
http://ee1394.com/bmw/docs/factory/repa ... s/0211.jpg
http://ee1394.com/bmw/docs/factory/repa ... s/0212.jpg
PM for details
PM for details
Hi Mark I lifted mine from the Chilton workshop manual, they are listed for a 91 M3 although they are the same for the 89 and 90. I'll need to get a definite answer cos my complete suspension is in bits at the moment waiting on a mate to weld the adjustment plates on. I've got camber plates for the front so it's going to need aligned when I'm finished. Perhaps I should just go to the dealers and ask what settings they use. How much difference to the setting figures will there be with different sized wheels.
Just so that I'm clear. My camber reading was -1 +/- 1/2 in degrees. That in minutes is -60 +/- 30 which means that you could set the suspension anywhere between -30 and - 90 ( 1 degree 30 Min's) If that is complete s#it do say so. I appreciate Mark that these figures are still not the same as yours.
does anyone know how to make a offline copy of this web site?E30Mark wrote:Hmm there seems to be some discrepancies between my data and yours Henry, unless I'm converting minutes / seconds to degrees incorrectly!
