Will they fit? '17' BBS Rims
irishandBMWmad
Thu Jan 10, 2008 6:57 pm
i have seen a set of BBS CH replicas fs
215/45/17 michelin pilot sports on front
205/40/17 marangonis on rear,
off a mazda 323 but fit anythin 4x100 et 38
Will these fit '87' E30 325i sport?
Last edited by irishandBMWmad on Thu Jan 10, 2008 7:35 pm, edited 1 time in total.
snoops
Major Helmet
Thu Jan 10, 2008 7:05 pm
should fit depending on centre bore and you will need spacers?
irishandBMWmad
Thu Jan 10, 2008 7:23 pm
what size spacers would i need? how would i find out about the centre bore?
Jonsku
Fri Jan 11, 2008 7:11 am
ET around 20 is ok with those. Centre bore is 57,1mn on E30 hub.
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
irishandBMWmad
Fri Jan 11, 2008 3:08 pm
So they would fit? you think they would look good>?
irishandBMWmad
Sun Jan 13, 2008 4:18 pm
Can i get some more posts i am going to look at these wheels and not still sure if they will fit!
Steviec
Sun Jan 13, 2008 7:17 pm
You may need spacers to make them clear the brake calipers and you need to find out what size the centre bore of the wheel is, this is the part where the bit that sticks out of the wheel hub site in. If the hole in the wheel is too small, the wheel will not fit and if too big, you will need some spigot rings (plastic rings) to fill the difference.
<a><IMG></a>
irishandBMWmad
Sun Jan 13, 2008 7:29 pm
Kool That is what i needed to know. the centre bore on an E30 sport is 57.2 mm?
Would u know how big a spacer i would need?
Anybody got these or samiler on an E30
so i could get an idea what they look like?
Thanks on new to the site and to E30 but really Kool and helpful site!!
BadDave
Sun Jan 13, 2008 9:38 pm
irishandBMWmad wrote:Kool That is what i needed to know. the centre bore on an E30 sport is 57.2 mm?
15mm hubcentric spacer should do the trick
Cost about £50 ish
BadDave
Sun Jan 13, 2008 9:42 pm
Should have added
Centre bore on the E30 is 57.1mm
Little bit of info for you
I run 7" wide rims with a 40 mm offset to clear my Brembos and use a 30mm spacer
They some times catch on the plastic arch liner between 3/4 and full lock
With 15mm spacers you might be ok
irishandBMWmad
Mon Jan 14, 2008 12:44 am
How would i find out the offset of these wheels??
BadDave
Mon Jan 14, 2008 8:11 pm
Should be marked on them
Look for the letters ET and a number just after it
the other way is to lay the rim on a flat surface, place a flat edge across the topof the rim and measure the distance from the face to the flat surface then divide by 2
then measure the distance from the mounting face of the wheel to the flat surface
Take this measurement(in mm) and deduct the 1/32 distance from that
This will leave you with the offset
Hard explaining without a diagram unfortunately
oldroydsr4
Tue Jan 15, 2008 9:31 pm
Where can i get the bbs replicas from (who makes them), i have never seen them in the uk and the originals cost a fortune.
irishandBMWmad
Thu Jan 17, 2008 11:01 am
i seen these for sell on a local car fourm, not sure were they were got from.
buncrana.bebo.com
